05-22-2019
00:04
16:10
05-22-2019
00:04
16:10
Hi there,
My current size L band needs to be replaced but I'm currently on the second tightest notch and have gone down about three notches this year (woo!). I was planning to buy a size S band when I got to the last notch but now my current band is worn out and desperately needs replacing. I don't want to buy another size L, only to have to replace in a few months with a size S. Is there an overlap in the S and L sizes? So if i'm on the second last notch on the size L, could I fit a size S on one of the outer notches or is there no overlap in the sizing at all?
05-22-2019 02:30
05-22-2019 02:30
Not a direct answer to the question but might help - I have just measured my Size S band and there is approximately 10cm between the band where it meets the charge 2 itself and the final hole. Mine is an aftermarket band rather than a FitBit one but I'm pretty sure when I compared it was the same size as the original one.
