10-09-2018
19:54
18:22
10-09-2018
19:54
18:22
Mine is stretching out too. I've had mine for many months but I've had to start using a closer notch for the little metal bit that holds the band together. I have a Charge 2 I believe and I have one of those longer bands with the two straps to hold it down so it doesnt hang loose. I'm not sure how a rubbery band like this stretches that much but it definitely has.
10-24-2018 08:37
10-24-2018 08:37
Hello @meghandot, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for bringing this situation to my attention. First of all, I've moved your post form the Charge to the Charge 2 board to keep the Forums organized.
At this moment, I've contacted our Support team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions.
In case you need anything else, please feel free to reply as well. Happy stepping.
01-09-2019 23:09
01-09-2019 23:09
Hello,
I bought my charge 2 in May 2018, and I've had the same problems. I've moved up 3 strap positions and I'm now on the tightest setting. If it stretches out further, I'll be forced to buy a new strap or stop using the product.
Could you advise?
07-17-2019 14:36
07-17-2019 14:36
My lose it app and fit bit app is not sincing. Should it?
