Charge 2 battery life decreased after firmware update
I charged my tracker to 100% less than 9 hours ago and now it is at 40%. I was having no problems with this until the update. I usually charge it once a week and it is perfectly fine. Now I'm going to have to charge it daily.
2 REPLIES 2
@aim91 Welcome! It's great to see you around!
Let me help you with your Charge 2 battery life. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
Your firmware update changed my Charge 2 battery depletion rate.
