Charge 2 battery not charging
In less than 1 year of use, my Charge 2 battery is dead.
I live in Brazil, FitBit has no authorized service in my country.
I can't find batteries to change.
I found a similar one,
https://produto.mercadolivre.com.br/MLB-1263316948-mini-bateria-37v-50mah-fone-ouvido-4mm-x-12mm-x-1...
the right battery is
https://www.joesge.com/products/fitbit-charge-2-smartwatch-battery-replacement-63mah-parts
I can use this similar model?
JF
2 REPLIES 2
@jgjfranco Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not charging. The Charge 2 battery isn't replaceable but you can try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here
Let me know how it goes.
Alvaro | Community Moderator
Hello
*** does not work ***
Not a problem with contacts, contacts are clean.
I give full charge, after 2 minutes it turns off.
And the battery icon appears empty.
and then it appears:
"exclamation mark" indicator
This site shows how to change the battery of Charge 2
https://www.youtube.com/watch?v=OEGAlQJbrmw
and my question is the same.
I can put this battery, it is not the same sold in US.
As I put in the topic above.
Noix
JF
Buy your battery at Joe's ✅ http://bit.ly/2z9kJuX 🔋 Click here to see all the electronics we repair. http://bit.ly/2DLAr2x Battery needed Fitbit Charge HR Battery Replacement 65mAh. This Fitbit Charge HR replacement battery can be found on our website. It will fit perfectly and get your Fitbit ...
