Charge 2 black screen won’t charge
Charge 2 has a black screen, and not charging, can anyone help with how to fix this, just randomly happened
1 REPLY 1
@stephaniethe Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 2 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help your device charge.
Let me know how it goes.
Alvaro | Community Moderator
