Charge 2 blank screen, green lights flash, but does not vibrate
Hi my Charge 2 was working fine and then screen went blank. I thought it needed a charge but when I plug it in no battery light comes on...it does not vibrate.  Left it charging for awhile & green lights on back flash but still no screen activity. It won’t sync and I have tried to restart it a number of times without success.
1 REPLY 1
@Lisap518 Welcome! It's good that the community is growing! Sorry to hear that your Charge 2 screen isn't working and thank you for sharing what you did to troubleshoot this. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes!
Alvaro | Community Moderator
