09-14-2022 22:48
09-14-2022 22:48
Good morning community,
i have a problem with my Charge2:
display is showing up with information from 2 days ago (time, date, steps). There ist no reaction to display touch or button- even restart (press several seconds) only gives a vibrate but nothing happens.
When connected to USB Charger there is no battery symbol (checked connection several times).
Do i have another option to regain my fitbit?
Thanks for any advise.
Best regards,
Katrin
10-04-2022 02:28
10-04-2022 02:28
Charge 2—press and hold the button on your tracker for 4 seconds. When you see the Fitbit logo and the tracker vibrates, the tracker restarted.
If your device is unresponsive:
Connect your device to the charging cable.
Press and hold the buttons on your tracker for 10 seconds.
Release the buttons.
Regards,
Will
Best Answer10-06-2022 20:05
10-06-2022 20:05
The above “fix” did nothing for my Charge 2. I believe it’s bitten the dust. Screen all pixelated. I’m bummed.
