06-02-2020
07:49
09:30
06-02-2020
07:49
09:30
My Charge 2 died about 14 months after purchasing. It's completely dead, won't charge, no life at all. Nothing has worked. Very frustrating to have a $100 paperweight on my desk. I looked at other postings, but no one had an answer.
Before you suggest holding the button for 4 seconds (or considerably longer), I tried that. I've tried all suggestions. Nothing. Junk.
06-09-2020
11:55
05:50
06-09-2020
11:55
05:50
@ColoradoPeter Thanks for joining us!
Let me help you with your unresponsive Charge 2 and thank you for troubleshooting this issue. Not sure if this could be a charging issue or a display one so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
Best Answer06-10-2020 08:50
06-10-2020 08:50
Hi there! No luck. Still completely dead.
10:40
05:50
06-16-2020
10:40
05:50
@ColoradoPeter thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
Keep me posted.
