Charge 2 connector broken, please advise
The plastic connector has snapped, bought in April 2020
Advice on good connectors to buy from?
https://linksharing.samsungcloud.com/sa01xJIavoiF
2 REPLIES 2
Hello @npapav and welcome to the Community forum.  My Charge 2 doesn't have those plastic connectors at all.  When I remove my band, I see just the metal frame with the "prong" sticking out like the top part of your pebble.  Are you using a third party band?  I think you just need a new band, which you will need to get from a third party site.
Laurie | Maryland
Hi @LZeeW and thank you. It is the original band when I bought back in April 2020.
I'm buying a new band for sure but if  I won't need the cnnectors like you say then that's better.  Thanks!
