07-09-2018
17:54
18:22
07-09-2018
17:54
18:22
My Charge 2 is a year and a half old. It has not been mistreated but it suddenly stopped working and has a black screen. It will not charge and only gets hot. I have tried the suggested charging for 2 hours and then pressing the button and it doesn’t restart. I am very disappointed that this device is only good for a year and a half. I cannot spend that much money to replace it every year and a half. It worked flawlessly until it just died. Any other suggestions ? My app now says no internet connection. My internet connection is fine. Let me
know if there is a way to fix this. My husband got his at the same time and his is fine. Only difference is he doesn’t track his sleep ?
07-10-2018 05:23
07-10-2018 05:23
Welcome to the Fitbit Community @16giraffes! Sorry to hear about the inconveniences you've been having with your Charge 2.
Since your Fitbit tracker is getting hot while or after charging it, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps.
Thanks for your help my friend @SteveH!
Point me out if there's anything else I can do for you in the meantime.
07-09-2018 23:53
07-09-2018 23:53
If you are in Europe then you will still be within warranty (it's 2 years in Europe, 1 year elsewhere) so you could contact customer support to see if they can help and, if not, discuss your warranty options.
You could try the restart a few more times as it's known to not always work. Can I just check that these are instructions you followed (it wasn't clear in your post that you held the button long enough):
Even if you are out of warranty it might still be worth contacting customer support to see if they can help in any way: contact.fitbit.com
07-10-2018 05:23
07-10-2018 05:23
07-17-2018 05:20
07-17-2018 05:20
Fitbit asked me to return the Charge 2 to them because it was overheating !
They sent me a return label and I returned it last Friday. I am waiting to find out what the next step will be.
Thanks for helping me with this issue.
07-17-2018 05:24
07-17-2018 05:24
This solution did not work for me because the Charge 2 was overheating a lot. Thanks Steve for getting a ticket created. I received a return label from a moderator and I returned the Fitbit Charge 2 last Friday per the instructions.
I am now waiting to see what the solution will be. Thanks again!
07-29-2018 14:28
07-29-2018 14:28
Hi,
My Charge 2 has just stopped working in the same manner. I have written to the support team. I'm curious if you have heard back from them yet, and what the final resolution was for your watch. Also, if you are in Europe, which country did you have to send the watch to?
Thank you.
08-03-2018 03:34
08-03-2018 03:34
04-19-2019 06:11
04-19-2019 06:11
My Fitbit is about 4 months old and it started getting hot on my wrist, then nothing. It won’t charge or anything. Anytime I try to charge it it gets hot to the touch. Anyone have any solutions for it?
07-29-2019 05:13
07-29-2019 05:13
Hello,
I have been having a similar problem with my Charge 2. It has been on the charger all weekend and shows that is is charging but will not actually charge and is overheating. It's about 2.5 years old, not sure what the lifetime expectancy is.
07-29-2019 11:03
07-29-2019 11:03
11-25-2019 02:10
11-25-2019 02:10
My fitbit alta has died and when I plug it in to charge, nothing happens but it keeps getting very hot. I bought a new charging cable but this has not made any difference. Can you please advise? Kind regards,
11-25-2019 02:15
11-25-2019 02:15
@EmmaMayGreen Best thing to do is to contact customer support via the following link. They can check your warranty status and advise on your options: contact.fitbit.com
11-25-2019 02:19
11-25-2019 02:19
Thank you 🙂
05-18-2020 04:41
05-18-2020 04:41
I have the same problem as @16giraffes. Could you send me the next steps as well?
06-06-2020 08:13
06-06-2020 08:13
I'm having a similar issue w my fitbit Charge 2. cleaned the sensor terminals and charger cable. the charge 2 is getting HOT, but not charging. doesnt even buzz when I connect it to charging cable
please help!
07-06-2020 18:23
07-06-2020 18:23
Mine was charging erratically, then started getting HOT while not charging. Mine was two years old. (Charge 2). this just happened over 4th of July weekend. Everyone else seems to be getting a replacement . . All i got was 25% off on certain models 😕 Guess i got the wrong Customer Service department
02-05-2021 06:04
02-05-2021 06:04
I have this exact problem too. Can you help with a solution?
02-05-2021 09:25
02-05-2021 09:25
