09-09-2019
17:42
13:04
09-09-2019
17:42
13:04
my fitbit was working fine. Suddenly on August 23, it stopped syncing with phone. I cannot get it to communicate anything. A friend looked at both and says the blue tooth on the fitbit may be turned off. I do not know how to turn it on. Please help. over 2 weeks and no change.
09-10-2019
09:04
07:47
09-10-2019
09:04
07:47
@elizabethabby Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 2 not syncing with your phone. I want to clarify that the bluetooth can't be turn off on the Charge 2. You don't mention the exact model of the phone you have. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
09-10-2019 10:15
09-10-2019 10:15
Mine doesn't sync either. My husbands Charge 2 doesn't even connect with the App
09-10-2019 10:23
09-10-2019 10:23
The bluetooth and location are on but the phone (Android 9) can't even seem to find the tracker.
If I try from the Fitbit App, it sees the Charge 2, "We found your tracker" and I get a code. But after filling out this code nothing happens. I get the advises: "Make sure your tracker is charged and turned on" [it is], "If there are other tracker nearby, move them away" [we dit] and "Turn off Bluetooth on your mobile device, then turn it on again" [I did several times, even rebooted the phone]. All this didn't help.
We've had a new App update, but this also didn't help
09-10-2019 10:24
09-10-2019 10:24
This doesn't help at all
09-10-2019 11:53
09-10-2019 11:53
09-10-2019 12:00
09-10-2019 12:00
Which phone? There's a known problem with the A8 (2018) discussed in the Samsung community. I've had weeks without it syncing (although still telling me about text messages etc) but I had another security update today which has fixed it.
09-10-2019 15:09
09-10-2019 15:09
09-10-2019 19:02
09-10-2019 19:02
Same thing on with my Fitbit and phone. I also have the Samsung galaxy j3 eclipse phone. Still waiting for help on this or I am calling it quits with Fitbit too!
09-10-2019 22:50
09-10-2019 22:50
I've got a A40 with Android 9.
