03-24-2020
08:04
10:14
03-24-2020
08:04
10:14
A week or so ago, I woke up to a frozen screen (frozen on the clock screen). That day I was prompted for a firmware update, which I did (thinking that it would fix the locked screen), but the firmware update did not complete, and now my screen is frozen on the update progress bar.
I tried putting it on the charger and pressing the button for 4 seconds, but it returns to the frozen progress bar.
Any clues?
Hope you are healthy and safe!
03-24-2020 08:20
03-24-2020 08:20
Have you tried restarting the update?
Best Answer03-24-2020 09:18
03-24-2020 09:18
Unfortunately, I can't connect to the fitbit at all.
Best Answer03-24-2020 09:25
03-24-2020 09:25
You can't connect to the Charge 2 or to Fitbit.com?
Was the Charge 2 removed from your fitbit account?
Best Answer03-25-2020 15:06
03-25-2020 15:06
I can't connect to the Charge 2. I can connect to the site without a problem.
Best Answer03-26-2020 06:17
03-26-2020 06:17
What is it you want to connect to what?
Let us know at what step the failure occured and what error was reported.
Simply stating "I can't" gives us nothing to work with.
Best Answer03-26-2020 09:00
03-26-2020 09:00
PS - "Simply stating "I can't" gives us nothing to work with." I understand this, but as a novice, I don't know what to report or what to try.
