03-07-2023
23:54
12:05
03-07-2023
23:54
12:05
I have multiple vertical flashing lines on the screen
Ive tried a restart and the Fitbit vibrates but screen just goes blank.
any ideas please?
03-09-2023 12:06 - edited 06-03-2023 11:28
Hi there, @GCHIP. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 2 before reaching out. |
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer03-09-2023 13:22
03-09-2023 13:22
Best Answer03-10-2023 04:39 - edited 06-03-2023 11:27
@GCHIP As long as your Charge 2 is syncing, this process can be done through the Fitbit app. To do so, please try the following:
Best Answer03-14-2023 02:24
03-14-2023 02:24
Hi,
This seems to be a very well documented issue with the Charge 2. I've had mine since June 2018 and the amount of problems I've had in the last couple of months is unbelievable. Everything about the Fitbit experience is going completely downhill, and as of last night, my Charge 2 developed the same well documented issue as the op's. What are my options regarding the Charge 2?
