03-26-2017
04:11
09:49
03-26-2017
04:11
09:49
I have had my charge 2 for about 1 month and all was well until yesterday.
I noticed that the heart rate monitor was not working, it wasn't glazing green or reading my heart rate. The only thing I could do was reset it and this worked overnight and until lunch time today when I noticed it had stopped working again. So I have had to reset it again to get it to work. Any suggestions please, do I need to send it back or is it something silly.
Thanks
01-06-2018 06:27
01-06-2018 06:27
01-09-2018 19:12
01-09-2018 19:12
01-09-2018 19:25
01-09-2018 19:25
I’m having problems with the heart monitor as well normally my rest heart rate is around 60. The last week or so it’s always in the 80s, 90s and even over 100 while I’m sitting. I’ve taken off the FitBit and it will randomly show a heart rate-tonight it said 109 while off. I was at the doctor today and they had my pulse at 76 but Fitbit was at 90. I’ve also thought my sleep reports are off- for example there are times it shows me awake for 25 minutes or more when I know I wasn’t awake. This AM I woke up at 130 but fit bit shows I was in REM sleep. Any suggestions on how to fix?
01-09-2018 23:56
01-09-2018 23:56
Mine is doing similar but it either doesn't register a heartbeat when the green light is on or it registers one when I am not wearing it! It has a knock on effect with the sleep tracking and my gym monitoring. I bought it for the heart rate and to help see what my sleep is roughly like but it's not very helpful like this.
I bought it for the HR monitoring but to be honest it's barely doing that and while I appreciate it is a rough idea this is far from that.
01-10-2018 13:16
01-10-2018 13:16
01-10-2018 13:19
01-10-2018 13:19
01-10-2018 13:20
01-10-2018 13:20
01-10-2018 13:23
01-10-2018 13:23
01-10-2018 13:26
01-10-2018 13:26
01-10-2018 16:01
01-10-2018 16:01
I just got my charge 2 for Christmas and my heart rate stopped working yesterday! My green lights are on but it’s not getting my heart rate, so frustrating. I turned it on to auto and on and have reajusted my band but nothing. Any advise?
02-08-2018 23:30
02-08-2018 23:30
Did the reset. It actually work. Let's see how long it lasts.
My situation:
- Green lights were working
- caught the HR monitor not working on the first date because it motivates me in the gym to work harder.
my only thought, is maybe, I need to wipe down the sensor every now then?
I can adjust it on my wrist and works fine.
The battery can get pretty low and still works fine. Don't know why this happened, was scared but I'm cool now.
02-23-2018 04:08
02-23-2018 04:08
I am having the same issue. Reset 3 times. Changed it to auto, synced. turned it off, synced, and back on and synced. I have 2 green lights (one is fainter than the other) and 2 dashes next to the heart.
Help.
02-25-2018 11:47
02-25-2018 11:47
Heart rate keeps going off. I've done the reset/ re-sync method several times. One day it works perfectly; the next day I'm just getting the heart with two dashes. I can remove the watch and the heart rate comes back on, but when I put it on my arm it stops again.
07-12-2018 07:17
07-12-2018 07:17
My Fitbit heart rate monitor quit working last week. I have done the resetting, syncing, and updating. It is set to auto... nothing is working.. I see two dashes -- all the time and no flashing lights.. Help?
07-20-2018 09:13
07-20-2018 09:13
My tracker is doing the same thing. No green lights are on. This happened after the battery died last night and was charged this morning. I tried everything listed here and even called customer support who just followed the same script. She did not understand what I was telling her and kept suggesting the same thing I told her I have already done. Your customer service is horrible so I am hoping this will be better. I have restarted my Fitbit like 10 times, I reregisterd in app, I have changed in app to off, auto, on. What can I do to make this work?!?!
08-29-2018 07:36
08-29-2018 07:36
I began having the same issue recently with the heart rate monitor intermittently not functioning. I tried resetting it 3 times in a row this morning without success. I tried it again with the same result. When I finish, the display shows Fitbit and “22.55.02”. The green lights are not flashing and the heart rate display shows “- -“. How do I change the setting from on to auto or auto to on? Is there anything else I need to do?
08-29-2018 09:36
08-29-2018 09:36
11-04-2018 07:06
11-04-2018 07:06
Heart rate not working/recording
11-04-2018 07:18
11-04-2018 07:18
Hi @Mishuggs01!
Have you tried factory resetting your tracker? Click the link below for instructions.
11-04-2018 08:45
11-04-2018 08:45
