01-21-2019
18:33
06:20
JuanJoFitbit
01-21-2019
18:33
06:20
JuanJoFitbit
Walked 200 metres and my heart rate was 170 peak. Now on train standing and heart rate is 145 cardio (I am standing still). I am a fit slim guy with a resting heart rate under 60 bpm. Charge 2 was rarely an issue. This Charge 3 is constantly incorrect. Great to get points on AIA Vitality for basically doing nothing though....
01-22-2019 17:00
01-22-2019 17:00
@japansuki Thanks for visiting the Fitbit Community.
I'm sorry to hear that your Fitbit Charge 3 is not recording your heart rate accurately. From your Tracker please go to Settings > Heart rate and follow these steps:
- Turn the heart rate off
- Restart your Tracker
- Turn the heart rate back on
Hope this helps. Let me know how it goes.
04-07-2019 17:42
04-07-2019 17:42
I have the same issue... my heart rate with the Charge 2 was around 60-65 bpm resting. With the Charge 3, it's around 70bpm. And I can be driving in the car, and look at my fitbit and it says my heart rate is 110bpm, i'm sitting down and driving. I can take my own heart rate and it's about 60bpm.
Just doesn't give me any faith in the product to be honest. This also affects my cardio fitness score.. annoying... i think i'll just have to take the fitbit off when i drive!!
04-07-2019 19:40
04-07-2019 19:40
@MrsBee74 Welcome to the Fitbit Community.
In addition to the instructions provided above, to improve the accuracy of the heart rate readings, we recommend following these steps.
If you have any question or are still getting inaccurate heart rate readings, please don't hesitate to contact us back.
Best Answer08-31-2019 12:51
08-31-2019 12:51
Samen issue. Sittin on my bench and heartrate 154.
09-07-2019 11:38
09-07-2019 11:38
same issue for me; tried resets; gave up and accepted "You get what you pay for."
09-07-2019 11:57
09-07-2019 11:57
How do you get to settings?
Best Answer09-08-2019 14:13 - edited 09-08-2019 14:20
@Karin555 @KDD125 Thanks for getting in touch. Sorry for the delay in my response.
@Karin555 Before contacting Customer Support for further assistance, you can perform a long restart which is a bit different than the regular restart:
@KDD125 You can find the Settings if you tap the screen of your Fitbit Charge 3 and slide to the left. For more information about how to navigate your Fitbit device's screen, please visit this article.
Please let me know if you have any questions.
Best Answer09-08-2019 14:32
09-08-2019 14:32
10-29-2019 06:09
10-29-2019 06:09
I am having similar issues. I look down at my Fitbit and my heart rate is 110, I take it manually and it's only 65. Every since I went to Charge 3, my overall resting heart rate is way higher. My workout peaks are ridiculously high too at times.
10-29-2019 16:41
10-29-2019 16:41
@jog916 It's great to see you in the Fitbit Community.
Sorry to hear that your Fitbit Charge 3 is showing high heart rate readings. Thanks for the troubleshooting steps you've performed.
To evaluate this situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed as soon as possible.
@KDD125 Thanks for your feedback.
If you need assistance, please let me know.
01-08-2020 12:04
01-08-2020 12:04
Same old bull**ahem** reply, they are just faulty and if I shake my hand fast for 30 seconds my fitbit shows a BPM of 170. Just admit they are restricted in accuracy during exercise although they do a good job when you are not exercising.
05-09-2020 12:48
05-09-2020 12:48
Mine was 175 whilst sitting down after an evening stroll during which I’d hit peak. It wouldn’t go down. I’m sat on the couch yawning! After the bpm disappearing the other day and the battery draining at a rapid pace, I’m none too impressed with this charge 3. I’ve only had it 6 months. Has yours gone back to normal now?
05-10-2020 04:05
05-10-2020 04:05
Best Answer05-10-2020 05:08
05-10-2020 05:08
Well I guess the reason why I bought it was to track my bpm and exercise correctly so that’s why I’m writing about it. Otherwise I wouldn’t wear it or be bothered about it, if you paid for something you want it to do it’s job or find a way to fix it and that doesn’t mean taking my pulse manually. Is there anyone who can help or suggest ways to fix this please?
05-10-2020 06:54
05-10-2020 06:54
Unfortunately:( I sent the watch to service and they changed with new one. And now, after 6 months new one isnt working too. Yesterday it is broken-down. I will send to service again and buy an apple watch:))
Best Answer05-29-2020 05:56
05-29-2020 05:56
i'm having the exact same issue with my alta hr. walking across my living room it read that i hit 200 bpm and sitting here at my computer typing this it's telling me 103. my resting (per the device) is usually in the low 60s to high 50s.
06-02-2020 17:45
06-02-2020 17:45
SOLVED! Same issue, I believe it started after a firmware update but I wasn't in my normal routine (I'm building a patio with long days of hard labor so the high HR and calorie burn seemed reasonable). My normal resting heart rate is around 60 but Fitbit Versa was showing 100-180. It was the loss of sleep tracking that caused me to realize something was wrong. I tried the suggested fix of turning off the HR monitor, restarting, and turning it on again. Did this 3 times. No joy. But then I:
1. closed the app on my phone,
2. turned off HR monitor on Versa,
3. turned off (not restarted) the Versa and left off for about a minute, then
4. turned on Versa,
5. turned on HR monitor,
6. opened the app and
7. synched with the app.
HR now 59. Fixed! Good luck! Shame on you Fitbit!!!
06-03-2020 03:29
06-03-2020 03:29
I also have a fitbit versa.and heart rate in the last three days has doubled.meaning the calories I burn are incorrect. And it's not showing my heart rate in my stats since Monday 😒
06-03-2020 03:45
06-03-2020 03:45
