09-17-2019
04:25
12:50
09-17-2019
04:25
12:50
Hi I’m 37 use the treadmill daily
normal 40 mins workout and my heartrate will go between 90-130 then couple times spike to peak, not everyday !
last 2 days within a min of getting on the treadmill I’m in peak 156 plus !!!
Tightened the wrist band , no difference
resting rate is between 60-65
any ideas ???? Can’t do my exercise for worrying
should mention when this happens I am not out of breathe can talk normally
09-18-2019
09:05
10:01
09-18-2019
09:05
10:01
@SunsetRunner Welcome! It's great to see you around!
Let me help you with your heart rate reading while on treadmill and thank you for troubleshooting this issue. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
