08-05-2019
18:26
13:57
08-05-2019
18:26
13:57
About 1 week ago, my fitbit (charge 2) stopped syncing automatically. I followed all of the troubleshooting steps (restarting my phone, the fitbit, the app, bluetooth, re-downloading the app, disconnecting the fitbit from the app). I tried all of these multiple times to no avail. Currently, the fitbit is disconnected and will not reconnect no matter what I do.
Does this mean that the fitbit is broken? I can't understand why this would have happened.
08-06-2019
11:39
07:15
08-06-2019
11:39
07:15
@Clecle, welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Charge 2 not syncing with your phone and thank you for troubleshooting this issue. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
Best Answer08-06-2019 12:12
08-06-2019 12:12
I’m using a samsung A8 which has successfully connected in the past. Restarting everything isn’t working. When I check the permissions, while location services are on, bluetooth isn’t even an option. Seems weird because it has connected to bluetooth before, so not sure why it wouldn't be listed. However, when I reviewed this comment: https://community.fitbit.com/t5/Android-App/Android-syncing-Permissions-Location/td-p/1622501, I noticed that it has all the same options as my phone (again, no bluetooth is listed) so I doubt that's the issue.
Best Answer05-17-2020 10:31
05-17-2020 10:31
Is this a ploy by Fitbit to get rid of older devices and force people to upgrade?
