07-12-2018
16:43
18:22
07-12-2018
16:43
18:22
I used to be able to get texts on my Fitbit but not anymore. Does anyone know how to fix that? Thank you.
07-12-2018 21:30
07-12-2018 21:30
I am having the same problem.
07-13-2018 00:46
07-13-2018 00:46
This may seem an embarrassingly obvious reply but have you tried turning notifications off and on again by holding the fitbit button?
07-13-2018 00:50
07-13-2018 00:50
If notifications are on but you’re still not getting texts then check: Account... Charge 2... Notifications and make sure text messages are selected 🙂
07-13-2018 05:03
07-13-2018 05:03
Text messages aren't even an option on mine
07-13-2018 05:40
07-13-2018 05:40
Have you got a Charge 2 and is is synced to your smartphone? You might be looking in a different place, rather confusingly there is another ‘notifications’ menu on the main account page where you can select notifications for step goals, badges, challenges etc. The one I am talking about is in the Charge 2 menu which you select by clicking the Charge 2 button with the picture of your watch at the very top of your Account page... I assumed everyone’s would be the same but I don’t know - I’m using the app on iPhone 7.
07-13-2018 05:46
07-13-2018 05:46
Welcome to the Fitbit Community @JSLEerin, @fay711, @Ktblonde, and @Robin7781! It's nice to see you guys around!
As my friend @Ktblonde mentioned, Fitbit Charge 2 has a Notification setting on the device. On the clock screen, press and hold the button.
Notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app.
For the ones who are using iOS, please go to your phone settings once again and make sure "Do Not Disturb" is disabled. If your phone is currently running iOS 11 or later, please go to your phone Settings > Notifications > Fitbit and make sure the following is enabled:
PS: The “Show in History” was wrong with mine. I had it turned off and that's why I wasn't getting my text notifications.
For the ones who are using Android, I recommend double check the following:
Hope this helps, I'll be around if you need further assistance!
07-13-2018 06:08
07-13-2018 06:08
07-13-2018 06:28 - edited 07-13-2018 06:29
Anytime @fay711! I'm glad to hear your notifications are back.
What's steps have you tried for the syncing issue between Fitbit and MyFitnessPal? I recommend to unlink the accounts and them link them again. Doing this should be able to resolve any issues between the account.
1. Sign into your Fitbit dashboard.
2. Go to the Applications settings on your account.
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts.
Note that only steps from your Fitbit will sync to your MyFitnessPal account.
Hope this helps, keep me in the loop!
07-13-2018 07:46
07-13-2018 07:46
07-13-2018 08:11 - edited 07-15-2018 06:47
First of all @fay711, make sure that your Fitbit account is no longer linked to MyFitnessPal. So, do the following:
Then, to connect your accounts again:
Catch you later!
07-14-2018 08:55
07-14-2018 08:55
07-15-2018 06:46 - edited 07-15-2018 06:47
Thanks for providing me with some details of your issue @Robin7781. Have you checked if your new Samsung phone is included in our list of supported devices?
If your tracker is compatible with the Fitbit app, I'd recommend doing the following:
Also, for call notifications, I had this issue last night, but I just needed to follow these steps:
This should allow your phone to recognize callers from your contacts list and their name should appear.
Hope this helps, keep me posted!
07-15-2018 07:03
07-15-2018 07:03
I was getting all notifications. Then I installed I've tried uninstalling, reinstalling, bluetooth off on....everything. Any advice?
07-15-2018 07:27 - edited 07-15-2018 07:28
Thanks for jumping in here @jasp7552, welcome! Thanks for already troubleshooting this notification issue, nice way to go!
Can you please let me know if you have checked and tried what I posted here? If so, try force quitting the Fitbit app and reopen it to sync your Fitbit device.
Notifications should work as expected after your device syncs. If they don't, continue with the next task.
Hope this helps!
07-15-2018 07:34
07-15-2018 07:34
07-15-2018 07:49
07-15-2018 07:49
It worked on the last attempt! So happy. Thanks!
07-15-2018 08:26
07-15-2018 08:26
07-15-2018 14:36
07-15-2018 14:36
07-15-2018 15:52
07-15-2018 15:52
I'm having problems with my fitbit hrs
