04-25-2018
15:48
18:54
04-25-2018
15:48
18:54
The sleep function omitted a day (no data) then worked/recorded a day and now is not working again.
04-27-2018 06:08 - edited 02-03-2024 07:09
Welcome to the Fitbit Community @Lgmbs! Are you still not receiving your sleep stages?
One thing I recommend is switching your heart rate setting to 'On' instead of 'Auto.' If the heart rate setting is set to 'On' your heart rate will always be active. Keep in mind that you need to record heart rate to calculate sleep stages. If you were to turn off heart rate, your sleep logs will go back to the classic style.
In addition, I think it's great that you update the Fitbit app to the latest version (iOS and Android). I always recommend keeping both the tracker and the Fitbit app up to date with the latest versions.
If you're not yet seeing Sleep Stages with your Charge 2 device, I recommend double checking the following:
You can also find plenty of additional information within this post.
Give this a shot and let me know if the issue persists!
Best Answer04-27-2018 06:08 - edited 02-03-2024 07:09
Best Answer04-27-2018 13:20
04-27-2018 13:20
Best Answer05-16-2018 11:09
05-16-2018 11:09
Hi Maria,
My sleep stages haven’t been working the last couple days. I have checked all the suggested settings from multiple forum posts. My heart rate is set to auto. However, I see no break in the feed for my rate. So I feel that can’t be the issue. One thing I know I did just before this stopped working was setup the Female Health Settings. So I wondered if that might have caused it. Any other suggestions?
Best Answer08-16-2019 05:35
08-16-2019 05:35
With the updated Fitbit app and firmware, I cannot find any way to set the heart rate settings to change from Auto to On.
My Fitbit is giving me “simplified” sleep data because it cannot detect consistent heart rate, though it seems to do fine during the day. It worked very well for a couple of years and now is unreliable. Is there a contact that might need cleaning or something?
