03-13-2024
14:11
06:19
03-13-2024
14:11
06:19
My charge 2 is not charging. I thought the charger might need replacing and bought a new one, but still it’s not charging anymore since Monday. Has Anyone an idea how to fix this??
03-14-2024 04:49
03-14-2024 04:49
@babe63 Fitbit recommends cleaning the charging contacts on the back of the device with a toothbrush and water. Debris can accumulate. If that doesn't work, you might have a dead battery. Rechargeable batteries have a lifespan. Your battery is at least six years old, very old for a rechargeable battery.
Laurie | Maryland
03-14-2024 06:23
03-14-2024 06:23
Hi there, @babe63. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that your Charge 2 is still not charging despite the charging cable you bought. We're to help you!
I agree with @LZeeW, as per the description of your post, it could be a sign the contacts need cleaning. Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
Nevertheless, bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning).
Additionally, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
03-14-2024 13:37
03-14-2024 13:37
