04-24-2017
11:02
09:49
04-24-2017
11:02
09:49
Is there any issue with Charge 2 active minutes. My tracker doesn't track the active minutes. This is my second tracker in a month. I usually workout 90 minutes everyday, active minutes does not log it.
05-05-2017 19:01 - edited 05-05-2017 19:02
My active minutes function is not working like it used too. The change only occurred over the last week or so. It's so frustrating. Any ideas?
Best Answer04-24-2017 12:03
04-24-2017 12:03
Is it an auto-recognised sport that you are doing or are you actually starting a workout via your wristband when you do it?
Best Answer04-24-2017 18:38
04-24-2017 18:38
I tried both. I even restarted my tracker for couple of times. It don't work.
04-24-2017 21:03
04-24-2017 21:03
I had the same issue as well.. I exercised for 125 minutes (i did "Workout" setting on my watch), but the main page of fitbit display detected 28 minutes active only..However, when you go to the workout section, it tracked the correct 125 minutes workout done. How can this not consistent?
04-25-2017 08:38
04-25-2017 08:38
I don't get it. It is frustrating after a great work out of 90 minutes. My active minutes shows 0. I had same problem with two different charge 2 bands. I'm going to try one more last time with new band, If problem persists then I'm done. I've to try another fitness tracking device either Garmin/ Apple. I think they have bug in the Charge 2 devices.
Best Answer05-05-2017 19:10
05-05-2017 19:10
I spoke with Fitbit people, they told me it is known issue in the charge 2 band and they are working to resolve it asap.
Best Answer05-05-2017 19:12
05-05-2017 19:12
Thanks - I'm glad it's not just me
05-05-2017 19:13
05-05-2017 19:13
Talk to them one time, they sent me replacement device.
05-08-2017 17:52
05-08-2017 17:52
Mine isn't working properly either. And it started within the last couple weeks too. Did you get an answer as to why?
Best Answer05-10-2017 09:33
05-10-2017 09:33
Mine started working correctly from last few days. Fit bit pushed a new update for the Android users though last week. Talk to the customer support one time, lets see what they say.!
Best Answer05-10-2017 12:27
05-10-2017 12:27
Mine has registered 0 for two days in a row now. Has never happened before.
Best Answer06-11-2017 18:36 - edited 06-11-2017 18:38
The "Accepted Solution" is NOT a solution. I am having this issue too. It just started Fri. Did a reset.. Worked Sat and did not again today. Extremely frustrating.
06-12-2017 08:12
06-12-2017 08:12
Best Answer08-14-2017 14:39
08-14-2017 14:39
Any idea if a fix? In the last 2 days mine has done the same thing always stops on 29 active minutes although it's logged more elsewhere
thanks
vikki
08-15-2017 00:44
08-15-2017 00:44
Best Answer08-15-2017 00:44
08-15-2017 00:44
Best Answer04-10-2018 07:49
04-10-2018 07:49
I made a YouTube video on how to fix the Charge 2 not tracking your Active minutes:
09-20-2018 08:20
09-20-2018 08:20
Have you heard of any response? I was at the gym for 90 minutes today, although my fitbit says I have 0 active minutes. And my heart rate is never right. I fear my poor fitbit is worn out.
Best Answer09-23-2018 16:32
09-23-2018 16:32
None of these fixes worked. This is now a year later and my Charge 2 is not quite a year old. Called Fitbit and tech tried everything too. Got an email 3 days later. “We’re aware of this.” Great so a year later it hasn’t been addressed and hasn’t been resolved. I’ll wait a few more days then call again. Very frustrating.
