04-24-2017
11:02
09:49
04-24-2017
11:02
09:49
Is there any issue with Charge 2 active minutes. My tracker doesn't track the active minutes. This is my second tracker in a month. I usually workout 90 minutes everyday, active minutes does not log it.
09-25-2018 17:09
09-25-2018 17:09
My Charge 2 hasn’t tracked my active minutes for the past 3 days. Dashboard says 0. It also isn’t counting steps accurately. I restarted it last night, but today it still isn’t counting active minutes.
12-05-2018 17:18 - edited 12-05-2018 17:53
I received my FitBit Charge 2 Sunday night and it’s Wednesday, only after 3 days the active minutes stopped working! I’m really mad at Fitbit for this! I tried restarting it, and then after I restarted it I tried to workout, but it still said 0! I even tried restarting it multiple times! I’m going to try and restart it a couple more times and see how it does tomorrow! If it still doesn’t work, that’s ridiculous! I’ve only had it for 3 going on 4 days, not even a week.
02-13-2019 17:12
02-13-2019 17:12
I called Fitbit Support and I followed their instructions and now it is recording active minutes. I reset the tracker and turned off heat rate. Synced Fitbit and turned on heart rate on to auto. Did this while following instructions from support team.
02-14-2019 05:24
02-14-2019 05:24
02-23-2019 10:35
02-23-2019 10:35
Thanks! Had this problem since a couple of days ago, solved!
08-08-2020 20:01
08-08-2020 20:01
Did you ever get any results? Having the same issue now.
