05-27-2018
10:53
18:54
05-27-2018
10:53
18:54
My Fitbit woke me at 4:30 this morning vibrating like crazy. Somehow the stop watch kept going and pausing, back and forth. So I placed it on the charger and did a reset. Then the notification on and off kept going back and forth, still vibrating like crazy. It will stop vibrating when on the charger and actually act right. Could it be damaged how? It has worked perfectly until 4:30 this morning. I never wear it in the shower or when using water.
I have reset it 5 times and after a few minutes, it starts acting up. Screen will also flutter from right to left.
05-28-2018 09:30
05-28-2018 09:30
Hey @RedsMom, welcome to the Community! The behavior of your Charge 2 sounds indeed odd and on the other hand, I appreciate the time you have taken to fix this issue by restarting it. Since this persists, I have escalated your case to our Support team so they can further assist you with this so keep an eye on your inbox.
Let me know how it goes!
05-28-2018 09:54
05-28-2018 09:54
Thank you. I let it die over night since its weirdness caused the battery to drain quickly. I reset it at least half a dozen times. It just had a mind of its own. I placed it on the charger this morning. So far so good, but I'm not holding my breath. I'll keep you updated while corresponding with tech support.
05-28-2018 20:04
05-28-2018 20:04
Mine has also been doing this off and on for three days. Please update this post with suggestions and feedback from tech support
05-29-2018 04:48
05-29-2018 04:48
05-30-2018 04:06
05-30-2018 04:06
Thank you so much for your response. So far so good. I am keeping my fingers crossed, but this is the longest it has been before it malfunctions.
05-30-2018 16:23
05-30-2018 16:23
Well it lasted not even 24 hours before going crazy again... this is so frustrating...did you ever hear back from support?
08-17-2019 09:46
08-17-2019 09:46
I have got the same problem.
How to fix?
01-19-2020 11:27
01-19-2020 11:27
Was a solution ever found for this problem?
Mine started with the notifications this morning, now it's the stopwatch.
01-20-2020 03:04
01-20-2020 03:04
01-20-2020 14:07
01-20-2020 14:07
Many thanks, Rappard
I assume you were within the warranty period?
01-21-2020 00:35
01-21-2020 00:35
