09-15-2022 08:21
09-15-2022 08:21
The battery shows 100% charge. No green lights are flashing on the back. The screen is black except when I tap and see full battery icon. Tried restart/reset, no luck. Help?
09-16-2022 13:24
09-16-2022 13:24
Wow, the green lights suddenly started working again!
09-18-2022 19:02
09-18-2022 19:02
Ugh, no green lights again. Nothing is registering. Battery shows 100%. Contact pins are all clean per the Fitbit article on how to clean contact pins. Tried restarting several times, no luck.
Best Answer09-27-2022 01:31
09-27-2022 01:31
Remove the device from the charging cable. The device shuts down. Important: Plug the device into the charging cable again. Try changing the clock face to one developed by Fitbit, not a third party clock face, and see if the issue gets fixed.
Regards,
Will
