11-14-2021 18:39
11-14-2021 18:39
My Charge 2 will no longer charge when attaching it to the charger cord. I've cleaned the contacts on my FitBit and the pins on the charger. Is there any way to tell if it's my charger that is bad or the FitBit is bad?
11-16-2021
16:16
08:12
11-16-2021
16:16
08:12
Welcome to the Fitbit Community, @ChandaJane. Thank you for letting us know that you've cleaned the contacts on your Fitbit and charger in order to charge your Charge 2.
If your battery stopped charging, try the solutions below:
Make sure you use the charging cable that came with your device, as most cables aren't compatible with other devices.
Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
Keep on visiting the forums.
11-16-2021
16:16
08:12
11-16-2021
16:16
08:12
11-17-2021 19:45
11-17-2021 19:45
I feel like a total bone head right now. Turns out the USB part of my charger wasn't plugged all the way in. All is good, thank you!
11-18-2021
04:23
08:11
11-18-2021
04:23
08:11
Thanks for getting back to us and I'm glad that all is good with your Charge 2 now @ChandaJane.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
01-15-2022 19:10
01-15-2022 19:10
Hi-
i have tried all of the tips and my Charge 2 appears dead. It’s not responding at all. What can be done?
Thanks,
01-18-2022 05:46
01-18-2022 05:46
01-18-2022 19:40
01-18-2022 19:40
Try and adjust the way the charger is on the FitBit. Mine wasn't charging but i just had to move the charger to the side and it fit, then it started charging.
01-19-2022 07:14
01-19-2022 07:14
Welcome to the Fitbit Community, @Lacinos. Thank you for your charging advise.
As you mentioned, sometimes there´s need to adjust the charging cable in order to charge the tracker.
01-19-2022 07:52
01-19-2022 07:52
Thank you. Unfortunately nothing seems to help!
01-19-2022 08:23
01-19-2022 08:23
Thank you for your feedback @Ndodson.
Please contact our Support Team in order to get assistance.
