09-02-2019
03:17
13:04
09-02-2019
03:17
13:04
Somewhat ironically my Charge 2 no longer shows its level of charge.I have searched all the menus but can't find it anywhere.Did the lastest uodate remove it?
09-03-2019
08:39
09:57
09-03-2019
08:39
09:57
@timpars Welcome! It's good that the community is growing!
Let me help you with your Charge 2 battery level. Please add this to the Charge 2 by following these instructions.
Let me know how it goes.
09-03-2019 12:06
09-03-2019 12:06
Thanks Alvaro, problem solved. If only every issue was so easily fixed.
05-02-2022 07:19 - edited 05-02-2022 08:46
Hi Alvaro -
UPDATE: I WENT THROUGH CHAT AND THE PROBLEM GOT RESOLVED, EVEN THOUGH WE WEREN'T SURE HOW IT HAPPENED
ORIGINAL POST:
My charge2 has just stopped displaying the battery level, except when I connect it to recharge.
I've worked through the Charge2 Manual, which hasn't helped.
I've gone into device settings on my PC version of the App, where I found Battery was Off in Menu Items, so I switched it to On - but the battery level still doesn't display, except when I connect it to recharge.
Advice please?
Thank you
05-02-2022 12:16
05-02-2022 12:16
Hello @iSeeker
Maybe this will help to add the battery screen to your Fitbit:
Open your Fitbit app and tap your profile picture then scroll down and tap Charge 2. Now scroll down and tap menu items. Place a check mark on Battery. Now just sync your Charge 2 to accept your changes. To see your current battery level press and hold your Fitbit’s side button.
I hope this helps. Let me know and 😃 Happy Stepping!
05-03-2022 03:52
05-03-2022 03:52
05-03-2022 04:59
05-03-2022 04:59
Hello again @iSeeker
I’m happy to see that you got your Fitbit Tracker to display the battery level as you desired. That’s fantastic news! Enjoy the rest of your week…😃 Happy Stepping!
