11-02-2019
04:03
11:53
11-02-2019
04:03
11:53
Worked fine for a year. Recently gives simplified sleep but never details and seems inaccurate. Have tried all the hints on the sleep page as well as updated software and restarted device three times. Three different watch band, both magic metic for exact fit and old fashioned with holes, worn on different levels of wrist from loose to snug to I am almost cutting off circulation. Nothing works. Very frustrate as this was one of main reasons for owning device. Seems this has happened to others . Fitbit doesn’t seem to be addressing this.
11-03-2019
08:11
13:30
11-03-2019
08:11
13:30
@Capedoc Welcome! It's nice to have you on board!
Let me help you with your missing sleep stages and thank you for troubleshooting this issue. As you may know, sleep stages may not show for the following reasons:
I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Best Answer11-04-2019 02:13
11-04-2019 02:13
