03-30-2019
17:58
16:45
03-30-2019
17:58
16:45
2 days back it stopped showing heart beats. Yesterday battery suddenly discharged to zero. I restarted, tried rebooting, but didnt sync. I disconnected from Bluetooth. Not I'm not able to find charge 2 on Bluetooth. I use android mobile and charge 2 since Feb '17.
03-31-2019 08:27
03-31-2019 08:27
@Kaustubh Welcome to the Fitbit Community! I hope you're doing well!
I will gladly assist you with this and thank you for troubleshooting the issue. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
Best Answer04-01-2019 10:07
04-01-2019 10:07
Thank you very much for the reply. I was able to sync my Charge 2. But the major issue now which still remains is my band got dead twice even when it was charged. Now it is now getting charged. Also it is not showing the heart rate as highlighted earlier.
I did the procedure which explained while connecting to the charger.
Best Answer04-01-2019 18:02
04-01-2019 18:02
It's dead. It is not getting charged ?
Is it some battery issue ?
Kindly suggest.
Best Answer04-02-2019 11:44
04-02-2019 11:44
@Kaustubh thank you for your update.
Since your tracker isn't charging please try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Keep me posted!
Best Answer04-02-2019 20:05
04-02-2019 20:05
Thanks for the reply. will try doing this and will update.
Best Answer04-03-2019 09:22
04-03-2019 09:22
No... It shows it is charging but actually not getting charged. Also one observation that after charger removed when shows low battery signal on the back side only one green light sensor blinks and not the another one.
Please suggest what should be done.
Best Answer05-01-2019 06:38
05-01-2019 06:38
Can some one please reply.
