Charge 2 not charging. And wirling
Not holding charge
1 REPLY 1
Firstly, check if using another charging method resolve the issue i.e., if you are using wireless charging, check if using cable charging resolves the issue. You can also try charging through a charger, MacBook, or Windows PC. ...
If that did not work, check if reversing the cable ends (i.e., inserting the charger end into the case and vice versa) clears the issue.
Regards,
Will
