01-10-2019
07:10
17:54
01-10-2019
07:10
17:54
I am trying to connect my charge 2 to my phone as my tablet device is no longer working. It keeps saying that I can't connect to my phone as it does not have Bluetooth le. How am I going to sync my tracker
01-13-2019
08:27
06:31
01-13-2019
08:27
06:31
@SunsetRunner Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Charge 2 isn't connecting to your phone. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Best Answer01-20-2019 14:49
01-20-2019 14:49
Best Answer01-20-2019 16:47
01-20-2019 16:47
Fitbit has a Bluetooth issue. Finally talked to a supervisor who admitted that to me. My iPhone can not connect via Bluetooth to my replacement Charge 2.
It is very disappointing. My Fitbit has been down for over a month.
Support promises a fix soon? I am not hopeful.
Best Answer01-20-2019 22:06
01-20-2019 22:06
I'm having the same issue with my replacement Fitbit
