Charge 2 not holding charge for more than 5 minutes
What is going on....plugged i t in.......says fully charged....but in less than 10 minutes NO CHARGE at all!
6 REPLIES 6
@Docpat Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not holding a charge. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
Have done all that you suggested....it still will not hold charge!
Sent from my iPad
@Docpat thank you for the update and sorry for the delay in my response.
I have created a ticket so our Support team can further assist you via email.
Keep me posted.
Thanks...my internet has been down for the past 4 days...back in business again.
Sent from my iPad
I had the same issue.  Contacted customer support and was just told it was toast.  I had used it for 2 or 3 years and they said there was nothing they could do, I would have to buy another one since they wouldn't replace it.
I also contacted support.  They said I was well past my warranty, I bought this 21/2 years ago, but they offered me a discount on a few models.  It's a help, but frankly I can get them cheaper other places without a discount.  The best price I found on the charge 3 is HSN.  This is frustrating as I have read articles that suggested an upgrade caused many of us to have the same problem at the same time.
