Charge 2 not holding charge longer than 3 minutes
My charge 2 was working fine then all of a sudden it started scrolling through all the windows without me pressing anything. I put it in. the charger ans it appear to solve the problem, except now it wont hild a. Charge more than about 3 minutes
1 REPLY 1
@Pratt1967 Welcome to the Community. Sorry for the delay in my reply.
Let me help you with your Charge 2 not holding a charge. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
