08-15-2022 11:40
08-15-2022 11:40
Charge 2 not holding charge for anymore than 10 minutes. Will say it is 100% then shortly after the charge 2 is dead. I connect it to the charger and the fitbit logo appears. After 5 minutes the battery is at 100%. Can someone please help.
08-19-2022 13:43
08-19-2022 13:43
Same issue with my Charge - same day... with mine the heart rate sensors were stuck on constant and it seemed to have drained the battery. Tried charging and resetting it multiple times - but the battery would go from 100% to 0% in less then an hour. I spoke with support and they said it was a hardware issue - in other words, time to bury it. 😞
Best Answer08-20-2022 09:57
08-20-2022 09:57
@Doco75 @1stBlackBelt All rechargeable batteries. like those in a Fitbit, have a lifespan. The Charge 2 was released about the same time as the Blaze and the Alta. All three forums have posts about battery failures. This should come as no surprise.
Laurie | Maryland
Best Answer10-28-2022 02:25
10-28-2022 02:25
f you have't, please take a look at these tips:
Clean the charging contacts on the back of your tracker to ensure they stay bronze or gold in color. To do so: Use a toothpick or a toothbrush with rubbing alcohol.
Clean the pins on your charging cable.
Regards,
Will
