10-29-2016 10:47 - last edited on 09-09-2020 10:26 by MatthewFitbit
12-30-2017 08:48
12-30-2017 08:48
I noticed it was marked solved and did not see solution, could you repost. I am receiving call notifications but not text.
12-30-2017 09:10
12-30-2017 09:10
12-30-2017 15:36
12-30-2017 15:36
12-30-2017 15:37
12-30-2017 15:37
I had to go to my iPhone settings and then notifications, then Fitbit and I had to turn on show in history and that did it. Hopes this helps.
01-20-2018 12:21
01-20-2018 12:21
Holding the button worked for me!! Thanks for the tip😀 to get notifications turned on!
02-26-2018 14:40 - edited 02-26-2018 14:50
I had the spinning Notifications wheel too. I could never get past it. The Charge 2 would sync, but no text messages or notifications.
Telling Bluetooth and the fitbit app to forget the Charge 2, then adding it back in fixed everything.
03-13-2018 19:52
03-13-2018 19:52
I tried that and it’s still not working. I get phone call notifications but no text notifications and when I press the side button, it says that notifications are on.
03-30-2018 08:21 - edited 03-30-2018 08:22
I purchased my charge 2 three weeks ago and notifications were working just fine until today. My text/call notifications is set as on, on my watch and in the app.
03-31-2018 11:50
03-31-2018 11:50
03-31-2018 16:48
03-31-2018 16:48
@Tanj89 imI'not sure which phone your asking about. but I would turn of notifications in the Fitbit app.
Chrarge 2 - notifications - three dots known as the hamburger menu - disable notifications. Then enableethis will force the OS to ask for permission.
04-27-2018 19:15
04-27-2018 19:15
My fitbit will not receive my calls or texts
04-27-2018 20:43
04-27-2018 20:43
@raqmen as mentioned above have you checked that the notifications are tirned on. Are you sure the Charge 2 is not receiving, maybe the unknown phone is not sending. Have you checked the settings in the phones OS and the Fitbit app? Has the phone been restarted. if it is an Android?
04-28-2018 16:31
04-28-2018 16:31
Is this even a solution?
04-28-2018 17:11 - edited 07-19-2018 19:56
Sure their is @qkittle I had to search out your other post to get the phone type that your having problems with.
Have you checked to make sure notifications have been turned on. on the Charge itself.
Checked the notification settings in the app and the phones notification panel?
Restarted both the charge 2 and the iphone X which has been marked as compatable for some time .
Checked the help site.
Have you read this thread in this board.
07-19-2018 19:31
07-19-2018 19:31
Samsung S5 won't display text or calls
07-27-2018 01:59
07-27-2018 01:59
I have tried suggestions including forget this devise and I still do not get call or text notifications
08-15-2018 05:16
08-15-2018 05:16
You are a genius!!! Thank you!!!!
08-19-2018 16:24
08-19-2018 16:24
Thank you! I stumbled across your message and your solution worked. Thank you again!
08-20-2018 00:13
08-20-2018 00:13
Your welcome, glad it worked for you 🤗
08-20-2018 00:17
08-20-2018 00:17
Happy it worked for you, Not all stumbles are bad 👍
