10-29-2016
10:47
10:26
10-29-2016
10:47
10:26
11-17-2017 09:00
11-17-2017 09:00
11-17-2017 09:27
11-17-2017 09:27
11-17-2017 12:34
11-17-2017 12:34
11-17-2017 12:49
11-17-2017 12:49
11-17-2017 14:15
11-17-2017 14:15
When you tap through the the Fitbit, stop and keep holding the button on notifications just for a moment until it switches to on.
Hope this helps!
11-17-2017 22:06
11-17-2017 22:06
11-18-2017 00:28
11-18-2017 00:28
11-18-2017 02:10
11-18-2017 02:10
11-18-2017 06:14
11-18-2017 06:14
Were you able to delete Old notifications?
11-22-2017 12:13
11-22-2017 12:13
Hello folks! I hope you are doin' great!
I'd like to give you a hand on this, so first of all, make sure that the notifications are ON on the tracker itself, press and hold the side button to activate or deactivate them.
If they are ON, please review the troubleshooting in this article to try to fix this and get text, calendar and call notifications.
Also, take into consideration, the following:
Let me know how it goes guys!
11-29-2017 11:17
11-29-2017 11:17
Wow! Thank you so much, I have been trying to fix it for so long and that did the trick! 🙂
11-29-2017 11:35
11-29-2017 11:35
11-30-2017 05:12 - edited 11-30-2017 05:13
Hey @cfran, welcome to the forums! Sounds pretty great that the tips posted in this thread helped you out to resolve the notification issues that you had with your Charge 2. I appreciate the update. 😉
@LisaFC, the same to you my friend, if you have further questions, let me know!
If you have further questions or comments, let me know!
12-07-2017 06:05
12-07-2017 06:05
This works! I have been trying for two months and missed this idea. Push the button on the left for a couple of seconds. My notifications were "off". Now they are on. And it works!
12-08-2017 06:03
12-08-2017 06:03
Hey @hot_rod_todd, it is cool to see new faces around! Sounds pretty cool that you are getting notifications again. Remember that you can turn them ON/OFF every time you want it.
If you have further questions, let me know!
12-14-2017 05:07 - edited 12-14-2017 05:10
My charge 2 text notifications were working fine until I got a new iPhone. I tried EVERYTHING! I know all about the notification option on the actual Fitbit. Turned my phone off and then back on. Deleted the Fitbit app and then reinstalled it. Removed the Fitbit from
the app and reinstalled it. Forget this device from Bluetooth and synced it again and again. Figured out the solution myself. I went into my iPhone notification settings for messages and had to make sure my “show in history” was on. The forum doesn’t mention this. Keep all notifications on in the Fitbit notification setting as well just to be safe. Good luck peeps!
12-18-2017 05:50
12-18-2017 05:50
Hey @T_cam007, it is nice to see new members around! There was a little change after the update to iOS 11. In "Notification Settings" on iPhone, under "Messages", there is now an option called "Show in History" this replaces the previous "Show in Notification Center" and it needs enabling to allow text messages to appear on Fitbit Charge 2. This resolution is posted in other threads so users with the same concern, can get it resolved and receive notifications. On the other side, I appreciate the update. 😉
Have a nice day!
12-25-2017 17:57
12-25-2017 17:57
I have iPhone 6s and Fitbit charge 2 and I cannot receive messages on Fitbit but I do gets calls. I have followed all setup setup steps and made sure my notifications are on and have deleted and reinstalled both Bluetooth and the app from my phone several times in addition to restarting my phone but still can't get messages. I have read other posts of others having the same problem and response was that the problem was being fixed by Fitbit engineers or someone but that was back in early months of this 2017 year. Has this been solved yet so that I know what I can do? Thank you
12-26-2017 05:09
12-26-2017 05:09
12-30-2017 08:05
12-30-2017 08:05
Thank you so much for posting!!!! Problem solved!!!
