10-04-2016
20:16
10:26
10-04-2016
20:16
10:26
I cannot get my Charge 2 to send any text message notifications. This is the 2nd tracker I've had due to the 1st one being deemed defective by Fitbit (syncing issue). I've tried everything on the troubleshooting page. Any suggestions?
03-21-2017 07:25
03-21-2017 07:25
I tried all the suggestions listed.
I unpaired and then paired.
I turned odd phone and on again.
and still not getting tex notifciactions on my charge 2 bracelet.
Best Answer03-21-2017 07:30
03-21-2017 07:30
03-22-2017 11:36
03-22-2017 11:36
Hey ...
i bought fitbit charge 2 before 1 month. Bt since last two days i have problem in that.. backlight which continuously blink when u wear it is not working so it cant track my heart rate distance etc. And also not shown any notifications
help me with this
thank you
Best Answer03-22-2017 12:49
03-22-2017 12:49
Welcome to the forums!
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussion forums and jump in. Hope to see you around!
Wendy | CA | Moto G6 Android
03-22-2017 12:55
03-22-2017 12:55
Hi @Niharshah92,
I'd first recommend making sure that you are using the latest version of the Fitbit iOS App, version 2.34. Click here to update if you haven't already.
In regard to your HR sensor, I'd first recommend restarting your tracker using the instructions listed here. If the problem persists, I'd recommend verifying that you have your heart rate settings configured to either "Auto" or "On", click here for instructions.
Lastly, I'd recommend the troubleshoots mentioned here in my previous post to help get notifications on your Charge 2.
Hope this helps!
04-02-2017 04:01
04-02-2017 04:01
04-13-2017 07:34
04-13-2017 07:34
Thank you! This resolved my issue.
Best Answer04-14-2017 07:09
04-14-2017 07:09
Hey guys! @GCha and @maca_s_2000, sounds pretty cool that your issue was resolved and that your Charge 2 is getting notifications again! If you have further questions, feel free to keep us posted!
Have a nice day!
05-02-2017 07:26
05-02-2017 07:26
I had the same thing happen - checked the App itself (that notifications were on), synced it. Then realized if you hold the button on the tracker it will toggle the notifications "on" or "off". I accidentally turned mine off 🙂
Best Answer05-03-2017 06:21
05-03-2017 06:21
Hey @catjrice, welcome to the Community! 🙂 That is correct, there is an easier way to turn ON or OFF the notifications, and you can do that on the tracker itself by pressing and holding the side button. So you don't need to go to the the app. 😉
Keep me posted if you have further questions!
05-05-2017 05:54
05-05-2017 05:54
Rich,
Thank you this is the first thing I have found about this step and it appears to have worked, was able to test calendar and phone and finally received the notification.
Best Answer05-08-2017 07:19
05-08-2017 07:19
Hi guys! I hope you are doin' fine!
@Lordbridle, sounds pretty cool that you are able to get notifications on your Charge 2. Thanks for the update my friend. 😉
@suncatinca, I appreciate you have tried to fix this by turning ON and OFF the notifications on your Charge 2. There are some other tips for Android device that I would like you to try in order to get the notifications. Let me know how it goes!
05-13-2017 21:23
05-13-2017 21:23
I have done all that has been mentioned but my Charge 2 still does not show any notifications. Any more advice?
Best Answer05-15-2017 07:47 - edited 05-15-2017 07:48
Welcome to the Forums @jeanlim!
I just want to confirm the steps you have done so far:
- If your tracker doesn't receive or there is a delay on the notifications
- How to enable notifications on your Android
- Make sure that the notifications are ON on the Charge 2 itself
Please let me know if you have followed them. 😉
05-15-2017 12:09
05-15-2017 12:09
I have performed all of these steps but when I go to the Fitbit App and click notifications the "wheel" keeps spinning and spinning with no next step. I was once receiving notifications but then it just stopped for some reason so it did once work.
Best Answer05-16-2017 08:10
05-16-2017 08:10
I recently bought charge 2 after two days the notifications have stopped working. I reviewed all the steps to no avail, so should I return it for a new one or is there a solution please advise.
Best Answer05-19-2017 16:59
05-19-2017 16:59
Holy crap. I have deleted my app a billion times. Reset Bluetooth. OMG. My notifications were off the whole time.!!! Thank you!!!!! Must have turned them off while sleeping!
Best Answer05-19-2017 17:00
05-19-2017 17:00
Push and hold button on clock face
Best Answer05-22-2017 08:15 - edited 05-22-2017 08:16
Hey guys! I hope you are doin' great! 😄
@SunsetRunner, thanks for taking the time to try to fix this. In addition, I would like you to take a look at the tips on this thread, I'm pretty sure you'll find the solution there! Let me know how it goes!
@suncatinca, I appreciate you have contacted Fitbit Support. What was the response that you received from them?
@fbourget, first of all, I would like you to make sure that you correctly set up your Charge 2. If you are using an iOS device, follow the steps in this post. And these steps for Android or these steps for Windows devices. If you are using a PC, review these instructions. After you have set up your Charge 2, let me know which operation system you used so I can keep giving you the correct instructions for you to get notifications.
@Devink66, sounds pretty good that you are getting notifications again! Yeah, on the Charge 2 itself, you have the option to activate or deactivate them.
Let me know how it goes, folks!
05-22-2017 09:31 - edited 05-22-2017 09:32
Every time there is an update to either my Fitbit software, the phone or the app, it seems I have to fix the notifications. This is what I have to do every time:
1. Open Fitbit App on phone
2. Click on the account button in the upper right had corner. Looks like a rectangle.
3. Click on Charge 2
4. Click on Notifications under General
5. You will see Calls, Text Messages and Calendar Events. Click on each of those to make sure they are On.
This usually takes care of my notifications.
