12-04-2017
14:08
18:54
12-04-2017
14:08
18:54
Why is it no longer recording rem,deep and light sleep patterns I just have chunks of time asleep and awake. Can you please update this application it needs work !!
12-09-2017 17:01 - edited 12-10-2017 19:25
To firm of a fit may stop the heart rate from being read.
Using the start now function will prevent sleep stages from being calculated.
If you go to the detail page of the sleep in question it will have an explanation of why your not seeing sleep stages, that is if it knows why.
12-08-2017 11:48
12-08-2017 11:48
Hey @Futurenow, it is cool to see new members around!
I'd like you to try to restart your Charge 2 by following the instructions in this post. Beside that, you have to take into consideration that your sleep stages could be affected by this:
Let me know how it goes!
12-09-2017 14:38 - edited 12-09-2017 14:52
Hi,
I have placed the device on upper wrist and firm as instructed. I chose the ‘sleep now
function.’ The device is still repeating the same simplified sleep logs.
Disappointed in the Charge 2 product, specifically, very poor software integration and absence of support of a dedicated application for the Ipad. It is both tedious and dated and requires a serious overhaul.
Take into account you are selling to other markets apart from the US- and a bunch of generic links to irrelevant ‘fitness’ guides and tracks with no relation to locality is absolutely useless to the user.
At this point, until, Fitbit lift their game I will likely be seeking refund on the device.
It’s just not cutting it guys. A device is only as good as its supporting software and the
software is very poor. A company of this size should absolutely be supporting software across multiple platforms.
12-09-2017 14:42 - edited 12-09-2017 14:48
I have followed directions as outlined. Placing the device further up wrist with a firm fit.
Best Answer12-09-2017 14:56
12-09-2017 14:56
EXCLUSIONS AND LIMITATIONS
Fitbit does not warrant that the operation of the Product will be uninterrupted or error-free. This Limited Product Warranty does not cover software embedded in any Product and related services provided by Fitbit. See the Fitbit Terms of Service for details of your rights with respect to use of the software and related services.
I csn can see you have essentially rendered the customer forced to deal with both shoddy software and error prone usage. This only further depletes confidence in both the product and this companies priorities, values and attitudes towards its customers.
12-10-2017 12:59 - edited 12-10-2017 13:03
Thanks mate. You nailed it. It’s the sleep now function that causes it to go into that simple mode.
I will give the device a chance, but would like to see some major updates to the FITBIt application - and I hope the company can see the need for this to occur. Using mobile apps on iPad is always terrible. A native edition would be welcome. Not everyone is using iPhone. Locality and theme customisation, higher resolution graphics, get rid of the ‘take a walk in Yosemite Park’ - for those who do not live in the US. It makes the user feel alienated by useless features.
Anyway, thanks again mate, you solved my issue. Appreciated
Best Answer12-12-2017 14:00
12-12-2017 14:00
My Fitbit has been showing the detailed sleep stages for a few weeks. Suddenly stpped and now only shows the simple.
Have never used the Sleep Now
Location of the band is the same
Battery good
Running version 2.62.1
Hear rate is set to Auto - there was full heart rate data for last night though. Just to be safe have switched it to On.
Looked for error messages but did not find any. where would they appear?
06-01-2018 03:33
06-01-2018 03:33
I had the old flex from 2014 till 2017 my husband got me the charge 2 was not set up till January/February and still in all that time had the new sleep pattern the rest is old sleep pattern been in touch with Fitbit loads try moving from left hand to right re set it loads of times still happens at six months old with same problem any help out there
Best Answer06-18-2018 22:34
06-18-2018 22:34
I agree. Hopeless. I bought a Fitbit specifically to track my sleep. Not only is is only giving me basic data which is useless but even that is inaccurate. Very depressing as I know i’m not a good sleeper but the Fitbit makes it worse than it is! Done all the restart stuff, worm it in the right place etc. Just a hopeless gimmick which stresses me out! Waste of money and i’ll now dump it and move on.
06-19-2018 06:15
06-19-2018 06:15
As mentioned above @Fredacat. does the app give any reason for not seeing sleep stages?
Is the sleep period at least 3 hours aznd the Fitbit is able to record a good heart rate.
06-19-2018 07:01
06-19-2018 07:01
Best Answer01-05-2019 05:56
01-05-2019 05:56
I have a charge 3 and am having this same issue if detailed sleep patterns not recording sometimes. I use the start sleep now function every night and it has given me the detailed sleep patterns for the past several nights until last night. So that is not the issue for me. I also wear my band exactly as directed on the non dominant arm.
01-05-2019 06:26
01-05-2019 06:26
What does your app say about you not seeing sleep stages @Zealouslyinert? This would be the place to start and a clue to why you might be seeing simple sleep.
10-06-2019 11:10
10-06-2019 11:10
Can’t get a sleep reading
10-06-2019 11:28
10-06-2019 11:28
Hello @bowler58 are you saying that you only see simple sleep, and not Sleep stages?
10-06-2019 11:33
10-06-2019 11:33
Not get detailed sleep pattern since August was fine till then
10-06-2019 11:52
10-06-2019 11:52
And what does the Fitbit app say about not seeing sleep stages. Look under the graph. I assume you still are getting simple sleep recorded?
Is the Heart Rate turned on, on the Charge 2?
10-06-2019 11:58
10-06-2019 11:58
10-07-2019 02:16
10-07-2019 02:16
Not getting details on sleep stages just the old one it just stop showing them from August
