08-18-2019
05:24
21:40
EstuardoFitbit
08-18-2019
05:24
21:40
EstuardoFitbit
Hey FB Comm,
I recently updated the firmware and since then my band doesn’t read the heart rate.
it just constantly says — (dash dash)
Also the sleep state and duration is incorrect. It was definitely working before now not anymore.
for example it will say that I only slept 2 hours when I know i was down for at least 7 hours.
any one else have this problem?
08-19-2019
08:30
12:07
08-19-2019
08:30
12:07
@LTSmash, a warm welcome to our Community!
Let me help you with your Charge 2 not recording your heart rate and sleep information. For the heart rate I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Regarding sleep stages you need heart rate data to get them. You may not get them for the following reasons:
Let me know how it goes.
Best Answer08-19-2019 16:51
08-19-2019 16:51
Hey Alvaro,
Thank-you for responding!
I performed the instructions as you asked. I turned off the heart rate, restarted the device and resync'ed.
I even tried turning off the heart rate and removing the device completely from my profile before re-adding it.
Unfortunately both steps did not work.
I did notice this occurred after upgrading the firmware, I'm wondering if other folks have had issues after upgrading also?
