07-07-2019
14:22
14:54
07-07-2019
14:22
14:54
So I’ve had my Fitbit charge 2 for 2 1/2 years and it has always recorded sleep stages. For the last 10 days it doesn’t record the sleep stages. I’ve rebooted using the charge cord numerous times. I’ve plugged in and rebooted from my computer on two separate times. I’ve also changed the heart settings from “auto” to “on”. I’ve even switched arms. I’m wearing correctly and not starting my sleep time. Can someone help me figure this out? What else can I do?
07-07-2019 16:07
07-07-2019 16:07
Same problem!!! Again!!! Fitbit, please fix this!
07-07-2019 16:07
07-07-2019 16:07
Hello @MagdalenefromNC let's open the Fitbit app and bring up one or more of the affected sleep records. Under the graph should be a reason for not seeing sleep stages. What is this reason?
Best Answer07-07-2019 17:08
07-07-2019 17:08
Same problem. Only shows sleep and restlessness
Best Answer07-07-2019 17:26
07-07-2019 17:26
So it’s telling me that it can’t get a consistent heart rate reading while I sleep. I’ve made sure it’s snug and I’ve experimented with moving it higher up on my arm and even switching arms.
Best Answer07-07-2019 17:45
07-07-2019 17:45
same here, have reset several times, switched arms, and wearing same way as last two years. It Shows times slept, but no stages since June 12. Sounds like a fitbit issue. Says couldn't get a consistent heart rate reading.
Best Answer07-07-2019 18:37
07-07-2019 18:37
Wearing it snug may keep the sensor from detecting the heart rate.
Fitbit suggests to have it loose enough for at least 1-2 fingers are able to slip behind the band.
Best Answer07-07-2019 18:40
07-07-2019 18:40
Best Answer07-07-2019 19:02
07-07-2019 19:02
How do you update to the latest version of the charge 2 software or reinstall the software on iPhone?
Best Answer07-07-2019 19:43
07-07-2019 19:43
Best Answer07-07-2019 19:48
07-07-2019 19:48
You can see your trackers latest version level in the help docs.
Best Answer07-08-2019 07:39
07-08-2019 07:39
Best Answer07-08-2019 07:47
07-08-2019 07:47
Same as others. Can’t get consistent heart rate. Wearing same as always. Seems to be a Fitbit problem.
Best Answer07-08-2019 07:49
07-08-2019 07:49
Best Answer07-09-2019 19:01
07-09-2019 19:01
I posted just this morning about how sleep tracking on my Charge 2 has gotten flakey over the last few weeks (seems like it was mid-June). Some nights it doesn't record any sleep. Other nights, it truncates a couple of hours off the start or end of my night's sleep -- times when I know I'm asleep.
It's been doing a fine job of tracking sleep for a couple of years now. This is a new behavior. I updated to the latest firmware (22.55.02) a few days ago but that made no difference. Fingers crossed it's an easy/inexpensive fix.
07-09-2019 19:13
07-09-2019 19:13
