02-15-2019
02:05
17:14
02-15-2019
02:05
17:14
My Charge 2 records differently almost every day... I walk between 40 and 60 minutes each day but it often records only 20 or so....plus my resting heart rate records for a short time but then has a straight dotted line.....
02-16-2019
05:04
07:29
02-16-2019
05:04
07:29
Hello @angelamasters, let me give you a warm welcome to the Community! When you say that your Fitbit only tracks 20 minutes after your 40 or 60-minute walk, are you talking about the active minutes or the total duration of your walk? And now about the heart rate, I'd like you to try the following workaround to fix this:
- Adjust the way you wear your Charge 2
- Turn off/on/Auto the heart rate monitor and sync your Charge 2 after every change
Let me know how it goes!
02-17-2019
03:27
07:17
HeydyF
02-17-2019
03:27
07:17
HeydyF
Hi … Thanks for your help...it does seem to have worked...I will be back in touch if the problem arises again...
Kind Regards
02-18-2019
07:18
07:28
02-18-2019
07:18
07:28
Sounds great that your Charge 2 is working fine now, @angelamasters! I appreciate the update. 😉
If you have further questions, let me know!
