03-09-2017
06:32
09:49
03-09-2017
06:32
09:49
My device notifies me when I get a call but unlike my HR it does not display the callers name. I have the same phone synchronization. I no longer have the HR.
03-10-2017 06:02
03-10-2017 06:02
It's great to see you around my friend @ReneIdell1, welcome welcome!
I had this issue last night, but I just needed to follow these steps:
This should allow your phone to recognize callers from your contacts list and their name should appear.
Hope this helps for you too!
03-10-2017 06:56
03-10-2017 06:56
I am having a similar issue and checked through the instructions you described. Permission is granted for this app yet my Charger 2 will still not notify me of a call or message. Any further suggestions?
Best Answer03-10-2017 07:26 - edited 06-25-2024 05:12
Thanks for stopping by @Hillymum!
Hmmmm... weird.
Be aware that notifications skip or stop occasionally for several reasons that don't suggest a problem with your tracker or the Fitbit app, such as:
Also, I'd recommend resetting your Bluetooth:
Notifications should work as expected after your tracker syncs. ![]()
Keep me posted sweetie!
05-02-2018 02:12
05-02-2018 02:12
I had the exact same problem when I upgraded from HR to a Charge 2, and my solution was very simple ... I scrolled through my fitbit device (not the fitbit app) and by pressing the side button on my fitbit several times, I came accross NOTIFICATIONS where I was prompted to press and hold the side button to “turn ON my notifications”. I guess the feature isn’t available unless you manually turn it ON on your device 🤷🏼:female_sign: Now that I did as instructed, my Charge 2 notifications work perfectly. Best of luck!
Best Answer09-30-2018 18:27
09-30-2018 18:27
My charge 2 is not showing my caller id. It shows unknown. I have uninstalled the app. I have changed the notification on it. I have hard booted it. I have unpaired and forgotten Bluetooth. Not sure of my options now. Even turned off and on again the notification on the actual charge 2. Please any ideas? Thanks
10-07-2018 13:56
10-07-2018 13:56
@Deedee2018 wrote:My charge 2 is not showing my caller id. It shows unknown. I have uninstalled the app. I have changed the notification on it. I have hard booted it. I have unpaired and forgotten Bluetooth. Not sure of my options now. Even turned off and on again the notification on the actual charge 2. Please any ideas? Thanks
I am having the exact same issue and have also reboited, reinstalled the app, made sure all permissions are granted...still getting the unknown.
11-12-2019 09:30
11-12-2019 09:30
I'm experiencing the same issue, however I've found a work around that's been successful for me. I go into my notification settings and simply run a test call. This seems to reset incoming call mode. I know it could be a pain to do after every call. Works until there is a permanent fix.
