03-24-2017
20:20
09:49
03-24-2017
20:20
09:49
I just got a Charge 2 and it worked fine for a week now It wont show incoming calls or messages ,any advise ?
09-17-2018 04:05
09-17-2018 04:05
received my Charge 2 yesterday and could receive texts and call alerts, now today I can’t. Very disappointed and frustrated as this tracker was the replacement for the Charge HR which stopped working during an upgrade.
09-17-2018 07:35
09-17-2018 07:35
Have you checked to see if notifications have been turned off on the charge 2, @Rexasorus. As mentioned above, hold in the button to check, you can also add the notifications screen.
If it is turned on then I would restart the Charge 2, by putting it in it's powered charger and holding in the button.
Lets restart the phone.
If it still doesn't work then the problem is with the phone and it would be helpful to know which phone we gave,?
09-17-2018 12:31
09-17-2018 12:31
12-08-2018 15:03
12-08-2018 15:03
Re: Charge 2 not showing calls or messages. Have tried all of the suggestions I can find.
Help please anyone?
12-08-2018 16:45
12-08-2018 16:45
@JET2018 is it only calls not showing? I assume your Charge 2 has notifications turned on. You can check by holding in the button, or adding notifications to the menu.
Otherwise the problem is not worth the Charge 2 but with the phone may I ask what type of phone the issue is with?
Have you checked the settings in the Fitbit app, and the permissions on the phone.
Lets go to fitbits help docs there is detail help for the 3 different phone OS'
12-08-2018 21:11
12-08-2018 21:11
It's an iphone 6Plus. Have followed all instructions and it seems to be an issue with the phone as call and emails from phone not coming through. Have tried resetting everything and followed other suggestions but still not working.
Thanks
12-08-2018 22:36 - last edited on 02-24-2020 14:08 by LiliyaFitbit
Hi
I have stumbled across a fix! Go to :
Screen Time
Mark Fitbit App as “Always Allowed”
This has now fixed my problem. Maybe helpful to others
01-04-2019 08:23
01-04-2019 08:23
I have only had my Fitbit charge 2 since Christmas 2018 (10 days)! At first the texts and calls were working then last night I realised I’d been having texts and calls on my phone but not showing up in my watch!!! I have tried the instructions on here several times (which I have to say I’m not happy about after only owning it 10 days!!!) and still not working! Not a very good start to my first Fitbit!!!
01-04-2019 08:25
01-04-2019 08:25
01-04-2019 08:29
01-04-2019 08:29
01-04-2019 08:35
01-04-2019 08:35
I also have 6s plus but have checked and already always allowed but mine isn’t working
01-04-2019 08:40 - edited 01-04-2019 08:43
Hello @Gina1902 have you held in the button on the Charge 2 to see if notifications or turned on?
Note of the button is held to long notifications will either be turned on or off.
If the Charge 2 says that notifications are turned on and the Charge 2 has been restarted the problem most likely will be in the phone.
If your phone or the Fitbit app had been recently updated, it is possible that permissions will need to be granted. In this case you will see that the Fitbit app has turned off the notification.
We will need to know what type of phone you have to be able to help?
First thing to check is there notification settings on the Fitbit app.
Then the notification permissions on the phone.
So you get your notifications displayed on the phone while the phone is locked?
This Fitbit help page has instructions for each type of phone, but they may be slightly different based on which version of the OS that you have.
How do I get notifications from my phone on my Fitbit device?
01-04-2019 08:44
01-04-2019 08:44
01-04-2019 08:49
01-04-2019 08:49
01-04-2019 08:54
01-04-2019 08:54
If the Charge 2 is set to receive notifications then it will display the notification as it is received.
If your not getting notifications on the wrist it is because the phone is not sending them.
I would check the phone settings, especially if the phone or the fotbit app has recently had an update.
01-04-2019 08:54
01-04-2019 08:54
I haven’t received any reply?
01-04-2019 08:55
01-04-2019 08:55
I’ve done all of what you suggest - nothing works!!! I’m really quite cross about it!!! It worked at first - no phone update - No reason at all for it to stop working!
01-04-2019 08:56
01-04-2019 08:56
Hi checked all setting no updates on either phone or Fitbit - not working
01-04-2019 09:09
01-04-2019 09:09
I would contact Fitbit, the link may also be found in the top right slide out menu above, under the help link found below or under help in the Fitbit app.
They have a phone number and live web based support. They will be able to step you through the process.
01-15-2019
12:12
10:16
01-15-2019
12:12
10:16
@Gina1902 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your can't receive notifications on your Charge 2 and thank you for taking the time trying @Rich_Laue suggestions. Please go to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. Additionally you can check the help site troubleshoot tips here.
Let me know how it goes!
