12-29-2018
05:37
18:22
12-29-2018
05:37
18:22
Not showing charging icon so it's not charging. I have restarted several times no change.
12-30-2018 09:52
12-30-2018 09:52
@SunsetRunner Welcome! Thanks for being part of our Community! Sorry to hear that your Charge 2 isn't showing the charging icon. Try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Let me know how it goes!
Best Answer12-30-2018 10:46
12-30-2018 10:46
Hey, my charge 2 is not charging at all. Tried cleaning with alcohol and swob, and still nothing. Did goggle trouble shot and from that, I may need a new battery. Where can I go to get one put in around Burlington, NC?
12-31-2018 07:30
12-31-2018 07:30
@userofcharge2 It's great to see that you've visited the Fitbit Community! Sorry to hear that your tracker isn't charging and thank you for cleaning the contacts on your Charge 2. Did you try the rest of suggestions listed in my previous post?
Please try them and let me know how it goes!
Best Answer12-31-2018 11:13
12-31-2018 11:13
01-01-2019 01:15
01-01-2019 01:15
It's a brand new Fitbit...should not have to clean it! I have done all you have suggested by charging in different ports/USB's and restarting with no result. My solution will be to return this as I should not have to do all this with something I have bought days ago and it's still not working.
01-07-2019 07:47
01-07-2019 07:47
@userofcharge2 @SunsetRunner thank you both for the update and sorry for the late reply.
@userofcharge2 since this didn't work the best thing to do is letting our Support team know so they can further assist you. You will get an email from them.
@SunsetRunner I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
I look forward to your reply1
