Charge 2 not syncing with Sony Xperia phone
Will not sync with my Xperia phone tryed uninstalling the app and then reinstalling it but no luck.
2 REPLIES 2
@JEDDAVEY280860 It's great to see that you've visited the Fitbit Community! Sorry to hear about your Charge 2 isn't syncing with your phone. Which phone are you using? Is it compatibleYou can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Alvaro | Community Moderator
Same prob and it doesnt work 😞
