12-06-2016 03:24 - last edited on 02-11-2021 11:00 by AndreaFitbit
I've had a fit but charge 2 for about a week now. Something is wrong with its sleep tracking feature. So far of the 7 nights I've worn the Fitbit it has only tracked sleep for 2 of them. I have seen posts where it was a sensitivity setting messing up the time asleep but mine has no data at all for most days.
Hopefully someone can asssit with getting this feature working otherwise the Fitbit is getting returned.
Thanks.
08-26-2019 16:58
08-26-2019 16:58
Welcome to the Community Forums @rebelry49, sorry for the delay in responding your post.
To better assist you, can you please let me know when was the first time you experienced this and how many times since then? Also, I recommend you to try sleeping with your Charge 2 on your non-dominant hand and check if the sleep settings on your account is in normal instead of sensitive. Please let me know if you're not receiving Sleep Stages or sleep information at all.
See you around.
10-27-2019 07:05 - last edited on 10-30-2019 20:09 by RicardoFitbit
I have a problem for a week now and Fitbit told me it is their problem They don ‘ t seem to know how to fix it very frustrating. I will contact amazon to see if they can help me for a return
Moderator edit: Format
10-30-2019 20:14
10-30-2019 20:14
Welcome aboard @Jocelyne2019, sorry for the delay in responding.
I totally understand how frustrating this can be for you and I apologize for that. Can you please expand on your issue so I can better assist you? If you're interested in a return process, please contact the retailer where you bought it, which in this case is Amazon, to receive further assistance.
Looking forward to your reply.
12-28-2019 04:37
12-28-2019 04:37
I go to bed around 9:30 - 10:00 PM and am asleep almost immediately. However my fit bit claims I am not asleep until around 3:00 am every night. What is the issue and fix?
Thank you much for you response.
01-08-2020 09:00
01-08-2020 09:00
I tried resetting my fitbit 3 time in a row. I t still does not give me my sleep data. It went from giving me scores and rem, light, and deep sleep to nothing.
01-12-2020 13:07 - last edited on 01-14-2020 14:59 by RicardoFitbit
Hi Jocelyn:
Thank you for your response. I am perfectly happy with my fitbit 2 for everything except the sleep data. Every evening I go to bed between 9:30 and 10:00 PM. I am fast asleep within 10 minutes of lying down. However invariably the fitbit does not show me sleeping until 2:00 or 3:00 AM which I know is not correct. I simply want to know if there is an adjustment I can make on my end to correct this situation.
I look forward to your response.
Ashley
Moderator edit: Removed personal information
01-12-2020 13:31 - last edited on 01-14-2020 14:59 by RicardoFitbit
I’m not currently using m Fitbit. I use garmin now . It’s been about two
years since I last posted to a Fitbit board . Though the last post was my
most up to date supposed fix by fit bit.
Though it should be noted I figured out I was a mover tosser and turner .
This gives the fit bit a false awake.
Hope the best for you
Sincerely; Shane
Shane
01-12-2020 13:37 - last edited on 01-14-2020 15:00 by RicardoFitbit
I go to bed every evening between 9:30 and 10:00 PM and am asleep within 5
- 10 minutes of lying down and yet my fitbit charge 2 claims I do not get
any sleep until between 2:00 and 3:30 AM. One night last week it had me
asleep for 56 minutes. I know I got much more sleep than that. Hopefully
there is a new adjustment or setting you can advise me to take to fix it.
Thank you for you response
*Ashley
01-25-2020 17:46
01-25-2020 17:46
Same here. I haven't had accurate tracking or a single sleep score since 10 January.
01-25-2020 17:51
01-25-2020 17:51
@Bronzbabe have you been seeing simple sleep?
01-30-2020 22:23
01-30-2020 22:23
Hi the sleep tracking icon is not active on my fit bit.. can you please let me know what I need to do ?
thanks !
viola
01-31-2020 13:01
01-31-2020 13:01
Hello @Vivaxx is this on your Charge 2 or the Fitbit dashboard?
Do you have the sleep icon?
I not sure what is meant by not active.
01-31-2020 13:22
01-31-2020 13:22
My sleep doesn't always register on my dashboard. There isn't any way to check my sleep on my Fitbit charge 2. Also I no longer get the average number of hours slept per week. Instead I get the average score or grade of how well I slept that week. It is the scoring that I wish we could opt out of on the dashboard, the daily and weekly.
02-05-2020 05:30
02-05-2020 05:30
My sleeping track is not accurate most of the time
02-05-2020 05:31
02-05-2020 05:31
Tracking sleep but not accurate Not even close
02-08-2020 23:45
02-08-2020 23:45
Stopped tracking sleep and as of yesterday, it's stopped track g heart beats.
It's useless for FIT TRACKING now so what am I supposed to do FitBit?
02-09-2020 02:54
02-09-2020 02:54
Hello @Bronzbabe what do you mean by stopped tracking sleep? You mention no heart rate, you should still be seeing simple sleep tracking.
02-09-2020 11:20
02-09-2020 11:20
I mean my fit bit does not always track, show, or register my sleep. Not even basic. That is you notice it isn't my main complaint. The main complaint is the scoring of my sleep.
02-09-2020 11:22
02-09-2020 11:22
Ah you work with Fitbit. Your perspective might be different than mine
02-09-2020 11:27
02-09-2020 11:27
Not knowing who "You" refers to @GudrunWiebe I'll answer. I simply A volunteer
