01-10-2019
05:23
17:54
01-10-2019
05:23
17:54
I have not used my Charge 2 since last May and want to get going with it again. It does not seem to power up at all. What do I need to do? Should I look at getting a new battery? If so, what size? Can I replace it myself or should I take it in somewhere?
01-13-2019
09:07
06:31
01-13-2019
09:07
06:31
@golfer100 Welcome! It's great to see you around! Sorry to hear that your Charge 2 isn't turning on. The battery on the Charge 2 isn't replaceable. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes!
