Charge 2 notification service not running with asus zenfone 4 pro
How can I get this to work in my phone? Are they compatible?
2 REPLIES 2
@Javier_Henao Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your notifications not working on your phone. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try the following:
  • Go to your phone's bluetooth settings and remove all devices listed there.
  • Restart your phone and restart your device
  • Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  • Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  • You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
Thank you very much for the instructions.
After following all of them I am getting phone call notifications, WhatsApp
nor Calendar are working.
Regards,
Javier Henao
