06-22-2019
05:58
15:06
06-22-2019
05:58
15:06
then I get sideways battery with ! in it and then the black screen.
This has been going on for 2 weeks. Tried cleaning contacts, restarting fitbit as indicated in help instructions multiple times. Turned off all notifications and automatic sync to phone. I am charging it using my computer. tried different USB ports. Mobile syncing devise is iPhone.
Any other suggestions? Is there an update to correct this problem?
06-23-2019 09:50
06-23-2019 09:50
@dlb1 Welcome! It's great to see you around!
Let me help you with your Charge 2 battery draining quickly and thank you for troubleshooting this issue. Since the issue persist please let our Support team know about this. I noticed that you already have a ticket with them so keep working with them to find a solution.
Let me know how it goes.
Best Answer06-24-2019 05:11 - edited 06-27-2019 14:54
I have the exact same issue...I will be very interested to see how you situation is resolved.
Edit: I have tried "rebooting" the device a couple times every time I put it in the charger. Still no luck. This is a very sudden thing too...not like I have had any indications my Bit had any issues.
Update: Since posting these questions about the battery life and my Charge2...all of a sudden (mmmmmm....really?) it is now functioning as it did before. This behavior went on for 4 days. And all of a sudden it is taking and holding a charge. I smell a rollback of an update...and if that is what fixed it then YAY!! Thanks Fitbit.
Bill
Best Answer06-24-2019 08:59
06-24-2019 08:59
Same issue here! Charged for several hours yesterday and the battery died shortly after removing it from the power source
Best Answer06-24-2019 10:22
06-24-2019 10:22
I just started having the same issue, after reading around it sounds like it's just the end of its life sadly. I got mine 12/25/16 and I've tried the cleaning, the restarting, and continue to get either the ! or an image of a full battery then it dies 10min later. If anything, try contacting Fitbit, but others have said that it's a waste of time
