12-29-2016
16:26
10:13
12-29-2016
16:26
10:13
I think for some reason my FB is counting too long a distance. Today we walked a pretty accurate 3.5 miles.
But Charge 2 said it was 4.4 miles. I looked to see how to change stride length (73 yr. old male, very active in refereeing
soccer and three workouts a week).
But the instructions are rubbish, calling for two different, nonexistent links to find where to adjust strides. What do I do? Thanks.
12-29-2016 16:57
12-29-2016 16:57
Good evening,
If you have a Charge 2, go to your App (I use an Apple), on the bottom right of the App there an "Account" symbol. Tap there then scroll down to the bottom and tap on Advanced Settings, At the bottom of that page there is a "Stride Length" where you can change it.
Hope this helps.
12-29-2016 16:57
12-29-2016 16:57
Good evening,
Hope this helps.
12-30-2016 07:43
12-30-2016 07:43
12-30-2016 08:23
12-30-2016 08:23
You can also shorten it. Have you manually measured your stride to be sure you enter the correct data?
01-06-2017 11:32
01-06-2017 11:32
No, I just took the distance shown on Google Maps/Pedestrian, over 14,000 steps, and divided it by the number of strides my Fitbit registered.
At some point, I have to admit that there's just an inconsistency with the Charge 2, and although it's disappointing, let go and move on.
01-06-2017 12:44
01-06-2017 12:44
05-19-2020 00:20
05-19-2020 00:20
It seems the bigger question is, if you have manually started and ended your exercise and tracked on the map in the app,why is distance still off due to a stride setting? I start Gaia GPS logging and my exercise in fitbit at the same time. Gaia is always repeatable yet distances in fitbit app charge 3 are always long by 0.1 mile or greater per mile walked. Apps on the same phone using the same GPS.
