05-20-2018
18:22
18:54
05-20-2018
18:22
18:54
One of the green LED heart rate sensors is out and the other sensor is continuously glowing. I charged it for 8 hours and the battery only lasted for 5 hours today. I’ve tried turning on and off the heart rate sensors and syncing with nothing happening. This is also the second replacement and I’ve only had it for 5 months.
05-21-2018 06:18 - edited 04-28-2024 07:11
Hey there @Andrew12, it's nice to see you around! Sorry to hear about the inconveniences you have with your Charge 2. Don't lose the hope my friend, let's see what's going on!
Because battery life is affected by use and other settings, actual results may vary. Consider these tips when you want to conserve battery life:
If one green light is still missing on the back of your tracker, I'd recommend restarting it by following these steps.
05-22-2018 10:52
05-22-2018 10:52
I have restarted it and the green light is still on and the other light still isn’t working. I tried syncing it again to turn the sensor to off and still no luck.
05-22-2018 12:51
05-22-2018 12:51
Thanks for getting back to me and trying my suggestions @Andrew12! Since this sounds a bit more serious, I've created a Support Case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
06-30-2020 13:37
06-30-2020 13:37
Hi, I have a fitbit charge 2 where the battery is not lasting very long and only one of the green lights is working. I have tried to plug in and reset, also tried turning the HR monitor off, syncing and then back on and syncing again. Nothing is working. Could you help please.
Thanks
Jamie
